Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 03-05-2005, 10:34 PM
JustinC9905 JustinC9905 is offline
Send a message via AIM to JustinC9905
Gas Mileage
I just bought a 04 Wrangler in July. It seems that I am getting horrible gas milage...I am getting just about 14mpg for highway driving. I have the 4L, 3.11 Axel Ratio, and 30'' tires and it seems to be driving just fine. Is this a norm? and if not, any suggestions as to what might be wrong would be appriciated.
Old 03-06-2005, 12:13 PM
Dr. Eagle Dr. Eagle is offline
That's very much the norm. I have an 00 Sahara with the 3 speed automatic.
You might try putting on a flowmaster, magnaflow, Gibson or Borla exhaust and especially a K&N air filter. It will help a smidge. Do you have a manual transmission? Is the vehicle broken in or brand new?
Old 03-06-2005, 12:35 PM
I have a manual transmission, and it has 3500 miles on it, mostly highway so I would consider it broken in.
I had a 94 Wrangler SE before this one, and I got much better gas milage with the smaller engine. I understand going with a bigger enginer causes you to lose some mgp, but I didnt expect it to be this bad.
Old 03-08-2005, 05:01 PM
JeeperRich JeeperRich is offline
Re: Gas Mileage
14mpg sounds low, unless you're a leadfoot.
When new, my '98 4L, 5spd got 18-20 around town, up to 22 highway (hardtop, 65mph cruise). Recently (95k miles) I'd get 16-17mpg highway (with mods), but drops to 9-10mpg cruising at 80-90mph.
Old 03-08-2005, 05:48 PM
Re: Gas Mileage
I thought it sounded a little low to me. When I went back and checked my records I was getting like 17mpg back in July, and now it has steadily declined for the past few months...and the only thing that I have added is a roof rack, but I dont see how that would drop the milage by like 2-3 mpg. Anyone have any suggestions?
Old 03-10-2005, 12:57 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Gas Mileage
O2 sensor will hurt your mileage, so you may want to have the dealer check it out under warranty.
Adding the roof rack will all a lot of wind resistance, so if you're doing 70 it'll eat some gas.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-10-2005, 12:58 PM
Re: Gas Mileage
Easy check for bad O2 sensor is the inside of exhaust is black and wet.
Had an '02 with hard top and 5spd, got 22-23 on highway also.
Old 03-10-2005, 04:16 PM
Re: Gas Mileage
Yea see the problem is that I calculated the extra drag the rack causes and the additional horsepower that the Jeep has to use to overcome it ( thats what I get for being a mechanical engineer) and it really wasnt that much. I dont know what the problem is, but the gas milage is actually getting worse as time goes on. I took it into the Jeep people and they said that everything was fine...they tried giving me the reason its gotten worse is the type of gas during the winter.
Old 03-10-2005, 06:06 PM
Re: Gas Mileage
How's the inside of the exhaust?
Old 03-10-2005, 06:12 PM
Re: Gas Mileage
I doubt the "gas theory", and the roof rack shouldn't add that much more drag, but speed will (you know, square of velocity, right?). Between no top and hardtop, my mileage varied ~1-2mpg.
Check the O2 sensors yourself, make sure your air filter isn't clogged, then ask the dealer what is in the gas -- he's probably just trying to get rid of you by blowing smoke.
Old 03-10-2005, 07:26 PM
Re: Gas Mileage
I will check the inside of the exhaust and see if its black. Also, I was wondering if anyone has had both a soft top and a hard top, and what if any difference they saw in their gas milage. Thanks for all your help.
Old 03-11-2005, 06:50 AM
Re: Re: Gas Mileage
Black and wet
Old 03-12-2005, 01:12 PM
Re: Gas Mileage
I checked the exhaust last night after driving it, and although it was black it did not seem wet. I didnt drive all that much, only like 5 or 10 minutes before I got to my destination, would that matter? Also, if there is anything else you can think of I would appriciate it. Thanks.
Old 03-13-2005, 10:57 AM
rad42 rad42 is offline
As a former victim of a bad O2 sensor I would look at that pretty hard. My jeep seemed to be running perfectly but my mileage decreased as well and by the time I got it figured out my Cat was ruined because the truck was running so rich. the result......$$$$ gone! Good luck
Old 03-13-2005, 11:39 PM
Re: Re: Gas Mileage
As I recall the EPA on mine with the automatic was 14/16. That is right about what I have been getting, although I have 32s on the vehicle.
