Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 03-05-2005, 09:42 PM
tiffjayq tiffjayq is offline
Please Help Me!
I have an 01 passat 1.8t and when i turn the steering wheel to either side it make this horrible noise, another problem is that when i try to use the signal lights they run for about 3or 4 seconds then i have to push the lever back up and try the signal light again (either side). sometimes when i begin to pull off froma stop sign or signal light they work. the last problem is that when i first crank up the car it makes this awful noise and keeps making this noise until u turn the car off. it like a cricket noise. please someone help me or give me some advice. thank you all.
Old 03-06-2005, 12:50 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
1- sounds like a power steering pump making noise-check the fluid level.
2- Your emergency flaser switch is faulty.
3- Cant really help ya there
Old 03-07-2005, 11:13 AM
Erik412 Erik412 is offline
Send a message via Yahoo to Erik412
Re: Please Help Me!
#3 Sounds like a loose or worn belt.
Erik
Old 03-23-2005, 08:46 PM
ericlr ericlr is offline
For #3 definitely have your belts inspected for wear. If you lose your serpentine belt you'll be calling AAA for a pick up!
