Old 03-05-2005, 08:43 PM
jdobbers2004 jdobbers2004 is offline
Question alternator wiring diagram
I have just bought a 1982 chevy pick-up with a 400sb and i was looking at the voltage to the battery and noticed it was around 8 volts. I took the alternator in and got it scanned and it has 15 volts, so i know that it isn't bad but i don't know the wiring diagram of a alternator to see if i can find a short in the wire maybe. could somebody send me a pic. of where the wires run from the alternator.
Old 03-05-2005, 11:14 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: alternator wiring diagram
Did they test the amperage output? Sounds like you may have some shorted diodes in the alternator. When the amperage demand is higher, the voltage will drop.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
