Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-05-2005, 08:08 PM
bigkane01 bigkane01 is offline
Angry 97 Ram idles rough after long driving.
I have a 1997 Dodge Ram 4x4 5.9(gas). I'm having problems with hesitation on take off and if I drive it long distances it begins to idle very rough and black smoke pours from the tailpipes. I have replaced the TPS,MAP,IAC sensors. Also changed plugs, wires, cap, button, and had an upper intake flush. Has anyone else had this problem? Does anyone know what my problem is? Any help is greatly appreciated. I'm pulling my hair out over this. Thanks.
Old 03-05-2005, 08:50 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 97 Ram idles rough after long driving.
Catalytic converter plugging or plugged.
My Mopars
Old 03-06-2005, 09:44 AM
My catalytic converter has been gutted out. It's been that way for a couple of years w/no problems.
Old 03-06-2005, 10:40 AM
I took it to my local autozone for a checkup with their handheld. They said I had a bad speed sensor. Does anyone know if a speed sensor will cause my symptoms of hesitation and rough idle after the long trips?
Old 03-06-2005, 11:40 AM
BleedDodge's Avatar
Might be your oxygen sensors?
My Mopars
Old 03-12-2005, 01:31 AM
Problem fixed, maybe, hopefully, knock on wood.
Well I broke down and took my Ram to local Dodge dealer garage and they told me I had a bad fuel pump. Although I haven't taken it on any long trips since I put in the new fuel pump, the hesitation issue seems to be resolved. When I stomp the pedal I get instant response. So I'll cross my fingers and hope the $400.00 pump fixed my issue.
Old 03-12-2005, 12:28 PM
BleedDodge's Avatar
Did your check engine light ever come on?
http://www.allpar.com/fix/80s-codes.html
My Mopars
Old 03-12-2005, 10:42 PM
Check engine light not working.
No my check engine light never came on. I don't think there's a bulb in there or it's just burnt out. I've had the truck a couple of years and have never seen a check engine light. I guess I need to check. The previous owner probably removed it. I got a repair manual for the Ram and had tried that self diagnostic thing, but with no light it won't help out. But as I said the Hesitation issue is definitely resolved. I'm happy with that. More than likely the rough idling and smoking was an overfeed of fuel since they have the pressure regulator built into the fuel pump module itself. Thanks for your help.
