Old 03-05-2005, 07:52 PM
angels7113 angels7113 is offline
please SHUT UP!
Does anyone else have the problem of there hatch rattling on every bump. Any one know how to make it stop the noises the noises.
Old 03-05-2005, 08:23 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Re: please SHUT UP!
Tighten all your bolts and check seals.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 03-05-2005, 08:43 PM
Scott82 Scott82 is offline
Re: please SHUT UP!
Also if you take the plastic off on the inside at the very back that covers tail lights ect. you can take the latch off and file some grooves in the latch to move it down, and if you have access to a welder then weld washers where you want you new holes for the bolts and it will be a much tighter fit and will stop rattling. I know its a lot of work for just a little rattle but i did this to mine 3 yrs ago and havn't heard a peep since
Old 03-05-2005, 09:02 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Re: please SHUT UP!
if you are talking about the hatch it's self, there are some rubber pieces you can twist one way or another. i suggest turning them out. i don't have a diagram of a hatch so here's the next best thing...
you're looking for the part of that pic that says "tailgate edge cushion"
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 03-06-2005, 02:38 AM
89si's Avatar
89si 89si is offline
Re: Re: Re: please SHUT UP!
exactly what i was gonna suggest. i made these little fancy rubber things stick out further, so it just closes tighter. you'll notice also that after you do this, when you open your hatch it doesnt just release, it will have some real 'pop' to it. its not necessarily 100% effective, but its definitely the easiest option to at least improve the situation.
89si-
78000kms on original engine.
sub is in.. lights are just about done..
Old 03-07-2005, 07:24 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: please SHUT UP!
This happens to CRXs as well. Custom taping in a similar part has solved the problem. I'm half deaf and I still had this issue.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
