Old 03-05-2005, 07:47 PM
peewee2 peewee2 is offline
Thumbs down 92 2.2 Cavalier not firing and fuel pump not running
Hello and help! WHAT I'VE DONE...I have put a new ignition modular in this 92 cavalier and a new crank sensor. I've checked for loose connections as well. THE PROBLEM...It will not fire and there is NO voltage going to the fuel pump. The windshield wipers arn't working unless you jump them. The radio won't work it is just static with no readings. HELP...Could anybody please help me fix this car! It cranks like crazy, but it won't start! Thanks.
Old 03-06-2005, 10:28 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 92 2.2 Cavalier not firing and fuel pump not running
Ok this is going to sound dumb but have you checked your fuses?. Also it can crank all it wants if its not getting fuel it will never start. Sounds like you got major electrical issue's. You need to check power to your relays. To make sure they are getting juice to trigger your pump and wipers.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-07-2005, 08:36 PM
amac209 amac209 is offline
Send a message via MSN to amac209
power will only go to the pump for about 2 seconds when the key is turned to run after being off for at least 15 s if the fuse is good and the wiring looks good the pump is most likely fried, common problem for chevy's). radio problem could be unplugged/broken antena wire. wiper problem could be fuse, wiring, switch, circuit board. actually if all these problems started at the same time the first check should be the batter, batery power& ground cables and body ground wires. good luck
