Old 03-05-2005, 06:21 PM
Patdineley Patdineley is offline
airbag removal
I need to know how to remove the airbag from the center of the steering wheel to replace my horn button. I tried to just pull on it but did not want to damage anything so I didn't pull that hard. Is there any tabs that I have to push in or anything like that? Any info would help
thanks in advace
Old 03-05-2005, 06:41 PM
Faze3's Avatar
Faze3 Faze3 is offline
Re: airbag removal
Might be worth looking into a Haynes manual.
Or at least telling us what year truck you've got.
Old 03-05-2005, 06:59 PM
Re: airbag removal
its a 2000, sorry for not saying earlier
Old 03-05-2005, 08:42 PM
mjgjr72 mjgjr72 is offline
Re: airbag removal
if you turn the steering wheel 90 degrees from center, there should be able to access a slot on the back, you need to stick a screw driver in the slot to release the tab, turn wheel another 180 degrees to do the same on other side, should be able to tilt bag forward to disconnect wires and then remove bag assembly, might want to pull the air bag fuse first to be safe
Old 03-06-2005, 09:02 AM
broughy84's Avatar
broughy84 broughy84 is offline
Re: airbag removal
yes, pull the airbag fuse first! You don't want an accidental setoff. Unless you like to pay hospital bills!
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 03-06-2005, 09:35 AM
silveradoman silveradoman is offline
Re: airbag removal
Pull the fuse and WAIT FIFTEEN MINUTES for the backup power source to drain, otherwise it could still go off, imagine the speed a phillips screwdriver will achieve if it is hit by the bag
Old 03-06-2005, 09:46 AM
bad68chev bad68chev is offline
Re: Re: airbag removal
I'd reccomend disconnecting the battery and waiting 15 minutes instead of just taking out a fuse, you want to know FOR SURE you have no power when wokring on an airbag.
Old 03-06-2005, 02:53 PM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
Re: airbag removal
id say remove any fuse that has todo witht he airbag then unhook your battery and wait 30 mins thats my honest thought
Old 03-06-2005, 05:24 PM
broughy84's Avatar
Re: airbag removal
If you want my honest to God opinion.....I don't F^%K with Air Bags, they hurt!
Matthew Brough
Old 03-06-2005, 09:16 PM
Re: airbag removal
yup! treat it like a live bomb
