Old 03-05-2005, 05:59 PM
silveradoking silveradoking is offline
Brake Light Mod
Hey, there fellow Silvyers....I just did the brake light mod, and am very impressed....now who ever is in the back of me gets blinded....he-he...
Old 03-06-2005, 12:29 AM
chuck16's Avatar
chuck16 chuck16 is offline
Re: Brake Light Mod
Err??? What mod would that be???
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 03-06-2005, 09:39 AM
silveradoman silveradoman is offline
Re: Brake Light Mod
LEDs??
Old 03-06-2005, 12:13 PM
zum-zum...
This is a really cool mod, the only down side is that you can't really see it...basically, all it is....when you push the brakes, the brake lights and turn signal lights turn on at the same time.....so when you push the brakes, instead of 2 bulbs going on, you have 4....neato, eh....?
Old 03-06-2005, 09:21 PM
Re: Brake Light Mod
What happens when you have your turn signal ON and your foot on the break? does the guy behind you see the turn signal or just gets blinded?
Old 03-06-2005, 11:07 PM
Re: Brake Light Mod
When you have your foot on the brake, and you turn on the turn signals, the turn signal blinks as usual...it will be as if you didn't do nothing...normal operation...
Old 03-11-2005, 10:02 AM
abadassbowtie abadassbowtie is offline
Re: Brake Light Mod
How do you actually do this
Old 03-11-2005, 04:23 PM
Re: Brake Light Mod
THIS IS THE LEFT SIDE...
-----------------------------ground(black)
BULB -----------------------------taillight (brown)
------------diode-----------brakelight (blue)
l
l
l______this wire to yellow wire in
trailer harness
-----------------------------ground (black)
---------diode-----------left turn (light blue)
THIS IS THE RIGHT SIDE...
BULB ----------------------taillight (brown)
------diode-----------brake light (dark blue)
l
l
l_____wire to dark green wire in trailer
harness
---------------------- ground (black)
------diode----------right turn (dark blue)
You need a total of 6 diodes and some 20 gauge wire.... Make sure the diodes are facing the bulb, and the wires that go to the trailer harness, are connected in between the bulb and the diode in the original wire.....hope you guys understand....make sure you solder everything and heat shrink it to make sure it doesn't fall apart....look at the diagram (the best I could do)...If you follow it, yo shouldn't have any problems, and the instructions above...any questions just ask.....
Old 03-11-2005, 04:28 PM
Re: Brake Light Mod
Sorry, guys the sketch didn't come out that good...there are 3 wires coming out of each bulb....a ground, taillight, and a turn signal or brake wire....a additional wire has to be added between the bulb and the diode and connected to the trailer harness (to be only done on the brake wire).....si unndestand?
