All of a sudden my power windows quit working on my 93 Bravada. Changed Circut Braker still not working. Windows will not work with either the master switch on drivers door or individual switches on each door. Any ideas what this could be?
Thanks Bill |
Re: Power Windows quit
You could try checking for voltage at your panel where the breaker plugs in with a volt/ohm meter. If you have voltage, check ohms across the breaker leads while you have it out of the panel.
Checked wiring diagram. There's only one Ground wire that comes from the main wiring harness. I bared the wire and jumpered ti a good ground source. BINGO WINDOWS WORKED! Installed new ground wire. Windows now working.
Allright, good troubleshooting Spenser!
