3000gt SL FWD Transmission prob
I just bought a 3000gt and I already have some problems, the transmission fluid was burnt and the car wouldn't move. I changed the fluid and the filter, then the car drove fine for about 4 hours then it wouldn't move. The car will drive in reverse, but it won't move in any other gear, like d, L, or 2. Some friends of mine told me to get the tranny flushed, I just wanted to know if I should just go ahead and buy a new transmission since the flush is gonna cost 150, and it might not fix it. Please help me, the car is just sulking in my driveway
Re: 3000gt SL FWD Transmission prob
Don't bother with the flush...I had the same exact problem where it wouldn't go in drive but would go into reverse (it's the 1st gear somethin or another)...the flush ($150) fixed it for about 2 days, then I ended up buying a transmission (and converting to 5-speed manual). So save your money..
You were doing neutral drops weren't you? |
I don't even know what a neutral drop is, but thanks for the advice I think I may go transmission shopping. I also have another question when I was changing my fluid I noticed the number on my transmission is W4A32, I thought the transmission for my car was supposed to be F4A33
my tranny busted back in december, and it was doing the same thing. would go into reverse fine, but as soon as I put it into 1st and tried to drive, it clank like a mofo.
time to get another tranny for you.
'92 3000GT VR4 Current Mods: K&N FIPK RPS Streetmax clutch Rebuilt tranny Free Boost Mod Maximal Performance Solid Motor Mounts Pictures and Videos of my car Got a question about your auto insurance? I'm an insurance agent, ask away. |
maybe thats your problem
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
how is that a problem
WTF? that's the DSM AWD transmission for auto Eclipses...someone must have welded the VCU and slapped it in there before you owned it. Or maybe they didn't weld the VCU and that's why it doesn't work. Yeah it's supposed to be the F4A33. All I can say is good luck on this one.
so how would I check and see if the transmission is welded right
DSM VCU's arent in the trans, all you have to do is put a VCU eliminator on it and its fine. Basicly just stop the output shaft from moving and it becomes a FWD car.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
o0o0o i didn't know that...i don't even know what a VCU is...i'm guessing Viscous Coupling Unit? I don't know what it looks like though.
if you can disable the output shaft and make it a fwd cant you also make it a rwd?
i have been thinking..... is it hard to do a auto to manual swap? i know about the extra pedals and stuff but does this not affect the ecu in any way? |
RWD would be harder in an ecplise than FWD, and im not exactly sure how you would do it. In a 3S you can weld the VCU, please dont do this to a good VCU, or you can take out the VCU and weld the planitary gears in the trans that split off the front and back. Then remove the front axles.
Re: Re: 3000gt SL FWD Transmission prob
