Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-05-2005, 05:22 PM
bdraulston bdraulston is offline
EGR location
I have a code 32 and I was thinking of replacing the EGR on my own. Where is it? Is it easy to do? Thanks in advance!
By the way, I almost forgot. It is a 95 ram 1500, 5.9, 4x4.
Old 03-05-2005, 09:02 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: EGR location
That might not be your problem.
In my case, I needed some gaskets replaced. The bad gaskets were causing the EGR to be unable to work properly, so that's why I got an EGR code.
Think about it.
My Mopars
Old 03-06-2005, 01:13 PM
netmech netmech is offline
Re: EGR location
lol i completely sealed off the egr tube.
Old 03-06-2005, 03:16 PM
BleedDodge's Avatar
Re: EGR location
How about at the base of the EGR valve, do you plug that as well as the tube, or should you just leave it open at the base of the valve?
My Mopars
Old 03-06-2005, 03:19 PM
joetib81 joetib81 is offline
I replaced my EGR on my truck. It is in the back of the motor on the passenger side. It is kind of hard to see the two bolts that hold it. But it is not really that hard to replace.
Old 03-06-2005, 04:15 PM
Re: EGR location
if the truck is older its a bitch to get the bolts off let alone getting your tool back there. BleedDodge i just torched the base of the egr tube and crimped it, the tube from the valve is not plugged.
