Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-05-2005, 05:22 PM
Dr. Eagle Dr. Eagle is offline
99 Tahoe Door Lock Problem
Hello all,
My son has a 99 tahoe and the electric locks work with the key fob, but the switches inside don't work. Is there a relay somewhere that works independent of the remote module?
Old 03-07-2005, 05:51 PM
84fiero123's Avatar
84fiero123 84fiero123 is offline
Re: 99 Tahoe Door Lock Problem
do none of the switches work or just the drivers door switch if its just the drivers switch then its just the switch, if all of them are not working then its a relay, but that doesnt sound like the problem. the relay controles both the lock mech. from the switches and the key fob
technology is great when it works
but one big pain in the ass when it doesn't
Detroit Iron Rules, all the rest are just toys!
Old 03-13-2005, 07:09 PM
Re: Re: 99 Tahoe Door Lock Problem
Neither of the door switches work, but the key fob does.. very strange... anyone?????
Old 03-19-2005, 06:31 PM
ttt
Old 04-15-2005, 01:09 AM
tertiarydog tertiarydog is offline
2 door locks went bad on left side and 2 on right side in five years. The cellanoids are plastic pieces of garbage. The key fobs sometimes don't work either. I have found that if there are a lot of overhead wires (high tension lines) or electricity cables nearby or radio signals, the fobs just don't work. Thanks GM. I'm not coming back. Bad brakes, bad experience aligning vehicle, intake gasket issues, fuel pump premature failure, thermostat seals are garbage, water pump fails, loses coolant constantly.
Old 11-15-2005, 08:32 PM
bgonline bgonline is offline
Re: Re: Re: 99 Tahoe Door Lock Problem
I am having the same trouble in my 97 Suburban - Did you get it fixed?
TIA
