Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-05-2005, 05:09 PM
cebooh22 cebooh22 is offline
How to bypass the second o2 sensor
Hi im new in the forum...
I have an accord with an h22a4 with a little probleme i would like to know how to bypass the 2nd o2 sensor on car.
and would like to know IF you don't do that what can it arrive ....?
And what is the symptom ???
Tx all
Old 03-05-2005, 08:25 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: How to bypass the second o2 sensor
you cant bypass the o2 sensor, because the ecu needs the readings from the o2 sensor. you can tell the ecu that it is running properly with an o2 sim. the only symtoms you'll get is a CEL and not being able to pass smog.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 03-06-2005, 01:16 AM
sivic02's Avatar
sivic02 sivic02 is offline
This is the hardest post ever to decipher...if you do have a check engine light, which I am assuming is why you want to bypass it. You can buy an o2 simulator as stated above for 60 bucks or however much those things are. Or you can buy a set of spark plug non foulers for about 4 bucks at an auto parts store, drill out the end of one, put the o2 sensor in it, screw that one into a second non fouler, and screw the two together into the cat. So it goes o2 sensor, drilled out non fouler, regular non fouler, cat. Just pushes the o2 sensor further away from the exhaust flow so it thinks you still have a working cat.
Here's to being single, seeing double, and sleeping triple
Old 03-06-2005, 10:46 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
www.o2simulator.com
Old 03-06-2005, 11:58 PM
sivic02's Avatar
Re: Re: Re: How to bypass the second o2 sensor
Originally Posted by toyme
i really dont know why you wanna do that but i think its kindna stupid to bypass the 2nd O2 sensor. Its function is just to monitor the oxygen content down stream or after the cat converter and has nothing to do with the engine performance.
The reason I did this is because I have a test pipe, which gives me a check engine light. Its just annoying riding around with the check engine light always on. Plus if anything DOES go wrong you wont know because the light is always on anyway. But you are right a secondary o2 sensor wont do anything performance wise, its just there to check and see if you have a functioning cat.
Old 03-07-2005, 12:05 AM
toyme's Avatar
toyme toyme is offline
Banned
Tx all
What kindna problem you got?
The function of 2nd O2 is just to monitor the oxygen contents down stream or after the cat converter. Your computer need it to monitor the cat converter. it will activate cel only when your cat is no longer working efficiently.
its a good shit to have and I think you shouldnt fuck with it.
Old 03-07-2005, 12:18 PM
Kind of a Big Deal
if u got to www.o2simulator.com and order one of their o2Sims, that will trick your ecu into thinking your cat is functioning properly, and theyre cheap.
Old 03-07-2005, 12:45 PM
sivic02's Avatar
My way is cheaper!
I am going to laugh if this has nothing to do with what the guy was asking because im still not sure what he was talking about.
Old 03-07-2005, 12:54 PM
AF - Advisor
i dont see how the o2 sensor still is able to read the o2 content and still not throw a CEL in this way. elaborate more.
Old 03-07-2005, 01:01 PM
sivic02's Avatar
http://www.k-series.com/forum/showth...ght=mechanical
Thats where I heard about it. The idea behind it is when you remove the cat the 2nd o2 sensor is going to have too much crap reaching the sensor that isnt filtered out, which will make it think the cat has gone bad. What this does is it moves the o2 sensor further away so a limited ammount of exhaust gets to the o2 sensor, it is a VERY little ammount that actually gets to the sensor but as long as it is considerably less than the primary o2 sensor then it wont cause a CEL.
If anyone sees this and decides to do this instead of drilling the hole with a 1/2 drill bit im not great at drilling a straight hole and 1/2" is about the whole non fouler, I used a 1/4" bit and it worked just fine so if you dont feel comfortable about using a 1/2" bit you can go smaller.
Old 03-07-2005, 01:20 PM
Kind of a Big Deal
i hate to break it to you, but your way.. even though its logical, wont work, the o2 sensor also reads temp, and if it gets ANY chane in temp, it will throw a CEL. The Sim keeps the o2 sensor in the same spot, and its still functioning, but the sim changes the code it send to the ecu, so the ecu thinks eveything is stock, but the sim doesnt change the temp readings. oh and the Sim is $30 shipped.
Old 03-07-2005, 01:53 PM
sivic02's Avatar
Hate to tell ya but it does work. I have had mine on my car for around 10k miles and there are plenty of others who have had theirs on their car for much longer than that. And still no CEL
Old 03-07-2005, 03:49 PM
Kind of a Big Deal
well then my friend... you proved me wrong and beat the system, congrats. why dont you post a pic so anyone that wants to know how to do it can have a pic and a description to help.
Old 03-07-2005, 04:03 PM
sivic02's Avatar
http://www.k-series.com/forum/showthread.php?t=8833
Old 03-08-2005, 07:17 PM
AF - Advisor
pretty good. looks like a pretty effective mechanical o
Closed Thread
