Old 03-05-2005, 03:10 PM
Tea Party Tea Party is offline
Fuel issue with 1996 4.3
Hello, I hope you guys can help me. I have a 1996 S-10 4x4 with the 4.3 liter x engine. It won't start when cold unless you give it a shot of ether. I heard that there is a part of the injection unit that gives it an extra shot of fuel when it's cold and that is probably the issue, but I can't find the name of that part anywhere. does anyone know it's name or have any suggestions? Thanks,
Kevin
Old 03-06-2005, 12:32 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Fuel issue with 1996 4.3
b4 you shot gun it like that, pick up some dry gas like heet or equivolent, go to your favoret gas station fill up and put a bottle or two into it, you may have some water in your tank
Old 03-06-2005, 04:41 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Ever changed the fuel filter?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-06-2005, 08:48 PM
I've run dry gas through it several times and changed the fuel filter about four months ago. Any other suggestions? Thank You.
Old 03-06-2005, 09:37 PM
do you hear the fuel pump priming? the full prime lenght too
Old 03-07-2005, 06:58 AM
dmbrisket,
I've thought of that too. It is running and about the same length of time it always has (at least I think so). It does seem to be better if I turn the key a couple times to build up pressure before I try to start it. Thanks for the help.
Old 03-07-2005, 01:47 PM
BlazerLT's Avatar
AF -Advisor
1.) check your battery voltage.
2.) check your fuel pressure whith the key to the first position before start.
