Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-05-2005, 01:37 PM
ROGERHAM ROGERHAM is offline
swaying
My96 slt has a drifting from side to side problem.
I'v cked all the bearings and bushings i can see, seem to be ok
I tightened up the steering box slacker adjer, but did not seem to help it.
Any help on this?
Thank you.
Old 03-06-2005, 04:38 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: swaying
how can you tighten the steering box? Please tell me how, I would like to know so I can do it on mine.
Also, I would check your tierods and idler and pitman arms for slack and wear.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-06-2005, 08:39 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: swaying
hex bolt on the top of the steering box, turn clockwise to tighten... Realize though that this is only a temporary fix..
Old 03-06-2005, 08:51 AM
BlazerLT's Avatar
AF -Advisor
Re: swaying
I have some slight steering slop and would like to tighten it up a bit.
Old 03-06-2005, 08:52 AM
rlith's Avatar
Re: swaying
change your intermediate shaft
Old 03-06-2005, 11:58 AM
Re: Re: swaying
Yes on the steering box adj.
Not sure on the intermediate shaft?
what does it look like?
Thanks for all the help.
Old 03-06-2005, 12:08 PM
Re: Re: Re: swaying
ok I have found the shaft does not seem to be slipping , but is some play there.
Old 03-06-2005, 03:31 PM
rlith's Avatar
Re: swaying
I just did a write up on this... In the blazer forum, search for Steering Slop
Old 03-13-2005, 09:08 PM
Re: Re: swaying
Thank for the help ,Read the arc you had on the blazer, Was very helpful
after cking things out more, I have changed out the steering box.
There was alot of slack it it.
Also put on new tie rods, Wll fnd out soon how well it worked.
Tnks
Old 03-14-2005, 04:30 AM
rlith's Avatar
Re: swaying
Don't forget about that intermediate shaft If you still have some left it's probably do to that..
Old 03-15-2005, 12:25 AM
Re: Re: swaying
Well found one prob today, was putting in new ball joints and found the pass side lower ball joint bolts were alittle loose, after looking at the bolts it was clear that they had been this way ,the thd was worn down on them.
Thanks for the help.
