Old 03-05-2005, 01:22 PM
Chrisjen411 Chrisjen411 is offline
Light Problem
Hopefully someone else has had this problem. When I turn on either head lights or running lights my left turn signal indicator comes on and stays on. Now it will flash when I out out my turn signal on but then goes back to staying on. Also my running lights in the bumper and also in the side maker do not light at all. I have replaced bulbs and it changes nothing. Any ideas out there. I am open for anything?
Old 03-06-2005, 02:43 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Light Problem
Your headlight dimmer switch is probably gummed up.
Try spraying electrical contact cleaner everywhere that it might seep inside, then flip the switches a few times to clean it.
You might have to remove the steering wheel, and just spray the contact cleaner right at the switches
Old 03-06-2005, 07:08 AM
smokey041369 smokey041369 is offline
you may also want to ckeck the grounds for these light as well
Old 03-06-2005, 07:33 PM
Cam1959 Cam1959 is offline
short in wet corroded bad ground bulb socket ? a burnt bulb filament? clean or replace bulb or socket ?
