97 Lumina Vaccume
Was wondering if someone could email me the vaccume diagram for a 97 lumina 3.1? [email protected]
The one from the service manual if possible!! |
Re: 97 Lumina Vaccume
What specifically do you need to know? Most vacuum diagrams in service manuals don't explain where what goes, but just gives a general idea on how it -should- work (at least that's how I feel)
Re: Re: 97 Lumina Vaccume
The EVAP purge solenoid has two ports, the rearward goes to the EVAP vac switch which then continues on beyond to the back of the vehicle. The frontmost port runs to the top of the TB, then goes to the PCV valve. If you still need a diagram I can scan one in from my 1999 service manual.
thanks, Don |
http://www.5in.net/vac.gif
image © 1997 General Motors 1 To EVAP Canister 2 EVAP Vacuum Switch 3 EVAP Canister Purge Valve 4 To Rocker Arm Cover 5 Air Intake Duct 6 Throttle Body 7 PCV Valve 8 Fuel Pressure Regulator 9 To Transaxle 10 Intake Manifold 11 To Accessory 12 To Vacuum Brake Booster 13 MAP Sensor |
