Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-05-2005, 11:42 AM
geraldl geraldl is offline
Question Question about the windshield washer bottle
I have a leak somewhere on the upper part of my windshield washer reservoir. The way it seems to be made is that it up wedge behind the driver's side bumper. Does anyone know I can get at it and get a look at it? How does that thing come out? Thx....
Old 03-05-2005, 08:09 PM
btw it's a 96 two door...
Old 04-01-2005, 01:10 AM
wizkiddrummer wizkiddrummer is offline
Just removed the same part
Hey,
I've been working on my 2004 pontiac sunfire and had to remove the same part. You have to pull off the fender, the wheel well shields and maybe the bumper (i forget) then u should be able to access the screws and push pins that hold it on. The screws will probably be 7mm and you'll need to pry to push pins off. On the bottom there will be a hose to where the fluid goes to the wipers and you will have to pull that off. Also there will be a clip holding a wire on the bottom. You will have to unclip it using a screwdriver. You can then pull the whole "bottle" down and to get the neck thru the car, just slide it over into he bigger hole. Hope this helps.
-Seth
