Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-05-2005, 09:28 AM
beryce20 beryce20 is offline
Thumbs up Keyless door entry programming??
I just got a 99 explorer sport, I was wondering if there's anyway you can program the keyless entry that's on the actual door, the dealership didnt know the number for it....
also, my door locks worked when i got it, then all the sudden the passenger side door lock doesnt lock with the button, any suggestions for this???
thanks guys!
Old 03-13-2005, 07:53 PM
ixoxoli ixoxoli is offline
Send a message via AIM to ixoxoli
you didnt give much info, but as far as i understand, you dont know where the number is located for your keyless entry
its in teh back, open the rear door/hatch, where the jack is located, look inside there should be a sticker with 5 numbers
Old 03-17-2005, 10:42 PM
smily157 smily157 is offline
Re: Keyless door entry programming??
Yea, you need the original 5 digit code, and then you can program a new code, but the original code will always work. It is located where the jack is in the back, down the side, it should be ontop of the wheel well
Old 03-19-2005, 01:30 PM
RouterDude RouterDude is offline
Once you get the code, you can enter in a second code that is easier for you to remember if needed by entering the original code, press 1/2 twice within 5 seconds each and then enter the new 5 digit code and the locks will lock/unlock to let you know the code was accepted.
