Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 03-05-2005, 09:16 AM
cuddabudda cuddabudda is offline
Question leaking antifreeze
3.2 chrysler engine, can't figure out where antifreeze is leaking. How many engine drain plugs, and where they are located?
Old 03-10-2005, 08:14 PM
NakedDancer NakedDancer is offline
Check the weep hole for the water pump: it's under the pully. There will be some white/green tral leading from it if it is leaking.
Old 03-19-2005, 04:04 PM
Bizzy102 Bizzy102 is offline
maybe you have a leaking head gasket. Are you loosing gas milage, white smoke out of the exhaust. Milky oil on dipstick. check that out then reply
Old 03-19-2005, 07:48 PM
Re: leaking antifreeze
Thanks grinno, all that is ok. It acts like an intake manifold leak. I've checked all freeze plugs, hoses and other key areas. It's pointing towards the upper
intake at the firewall side of the engine.
