Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-05-2005, 08:38 AM
britehope britehope is offline
engine getting hot
I have a friend with a 1993 honda accord that gets close to the red line. Change the fan motor and check the temperature swithch. Only cools down when the other fan kick on at high speed. What could be causing it to run hot at normal drive conditions? The thermostat is working.
Old 03-05-2005, 10:34 AM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: engine getting hot
Have you checked the coolant level? Also have you checked to make sure that the cooling system has no leaks? If the system has any leaks and cannot hold pressure than the boiling point of teh coolant lowers and it will not cool the motor near as well. One of the first things I would check if the coolant level is fine is the radiator cap, also how long has the coolant been in the car (when was it last changed)?
Old 03-05-2005, 12:14 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
http://www.automotiveforums.com/vbul...d.php?t=364612
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
