Old 03-05-2005, 03:57 AM
nicecar's Avatar
nicecar nicecar is offline
Unhappy aaaaaahhhhhhh!!!!!!
two words that sound good,
CARBON FIBER.
could anyone give tips coz i follow a tut but it doeznt work 4 me!!!!!
here is the link:
http://www.digimods.co.uk/tutorials/carbonbonnet.htm
it wont work 4 me so cud NE1 give me a tut???
chris
I'm the kind of guy who appreciates a fine body regardless of the make.
Old 03-05-2005, 02:00 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Re: aaaaaahhhhhhh!!!!!!
Why does that tut not work?
MAKE ART, NOT WAR
Old 03-05-2005, 02:41 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
that tutorial never works for me either, actually ANY carbon fiber tutorial I try anymore does not work, I dont know what happen. My first chop with CF worked perfect, Did the same on the next and now it will just NOT work.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 03-05-2005, 03:30 PM
Stingray 60's Avatar
Stingray 60 Stingray 60 is offline
I gotta agree that tut was one of my first trys too and gave up in frustration.
I gave it a run this afternoon and got it to work with half assed results but got it to go.
You must uncheck layer 1 (the bonnet) to see your work or the hood that you made a copy of will simiply cover it on step 11.
Also make sure the fill layer is set to 70% opacity or you wount see your car at all.
Hope this helps..
Old 03-06-2005, 01:20 AM
nicecar's Avatar
http://uploadhut.com/view.php/34824.jpg
this is what happens to me
chris
Old 03-06-2005, 02:13 AM
KustmAce's Avatar
Ok, here's how to fix that:
First make sure you have a layer that is just the hood. Now, before you put in the pattern, adjust the brightness and make the hood layer fairly dark.
Secondly, your CF pattern is way too big, shrink it a bit.
And finally, all you have to do after you have a smaller pattern and a darker hood if just lower the opacity on the CF layer.
Try adding a bit of a twirl to it too.
You may have to play with the brightness and contrast settings, as well as the size of the weave to get it to look right, but you'll get the hang of it.
MAKE ART, NOT WAR
Old 03-06-2005, 02:15 AM
nicecar's Avatar
Re: Re: aaaaaahhhhhhh!!!!!!
thanx mate! will try that now
chris
Old 03-06-2005, 02:29 AM
nicecar's Avatar
i got it done with a new method
i feel a tutorial coming on!!!
chris
