Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-04-2005, 09:38 PM
paulsantangelo paulsantangelo is offline
hot 92 rodeo will not start
Hey All:
Hope someone can help!
If I drive my 92 rodeo around for 20 minutes and then shut it off for 3 minutes, the engine will not start. It does crank but never catches. I will try to turn it over but will give out. When I do get it started, the procedure was to turn the key, let the key go and press and hold the gas pedal down to the floor. If it catches what will happen is that well its almost like the engine is thinking about starting up. The idle is almost at zero and is hovers for a couple of instances and the the idle just goes up. The engine is started.
Any ideas??
Thanks
paul
Old 03-04-2005, 11:33 PM
ilanpro's Avatar
ilanpro ilanpro is offline
Re: hot 92 rodeo will not start
Do you hear the fuel pump??
My other car is a hyundai
Old 03-05-2005, 10:59 AM
Yes, I believe I do there is a noise after I release the key and the starter stops.
Two sounds are made.
