Old 03-04-2005, 09:35 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
Talon purchase concern.
Hey all I found a stock 92 talon NA. with 110k on it for $2500 my only concern with the car is when its idling it makes a clatter like sound. The guy said its probably the timing chain (Thats exactly what it would sound like if it were that) But im not too sure. What could this be and does it sound worth it? Its in great shape other wise. Gimme some advise! Thanx..
1991 Eclipse GS-T
Exterior: stock
Interior: Boost and A/F gauge, TV/DVD player, thats about it.
Motor: supra side mount, hard pipes, greddy type s, greddy profec b b/c, nology hotwires, 3 in. turbo back exhaust.
Wheels and tires: stock shitty fan rims with stock tires (no grip what so ever)
Old 03-04-2005, 10:12 PM
Raz_Kaz Raz_Kaz is offline
Re: Talon purchase concern.
2500 without him fixing that issue is too much. Got my 1st gen talon N/A for 2 grand canadian.
Old 03-04-2005, 10:16 PM
irupp33's Avatar
Yea were still negotiating. He says he'll fix it but my only concern is that he said its a chain but i went to autozone to price a new one and the guy at the counter said that particular car uses belts. Whos right?
1991 Eclipse GS-T
Exterior: stock
Old 03-04-2005, 10:20 PM
Well there is a timing belt and a timing chain. My suggestion for you is to have him replace both as the timing belt would need to be replaced again within the next 10k miles or so to prevent free-wheeling or interference
Old 03-04-2005, 11:42 PM
awd_n_it awd_n_it is offline
Send a message via MSN to awd_n_it
Re: Re: Talon purchase concern.
Can you please show me where this "chain" is? Because i think Mitsu. must of forgot to put it on all 3 of my DSM's!!!
I would say don't buy it. You can find a good turbo DSM for that much just search around. That is unless a N/A DSM is what your looking for? i don't know why you would want a N/A DSM, but you never know.
(Early) 1992.5 Eagle Talon
TSI AWD 5 Speed
Old 03-04-2005, 11:57 PM
DSMNerd6889 DSMNerd6889 is offline
I'm selling the 95 TSi in my sig for $4000, and it has only 60k on the new engine.
1990 GSX
PTE SC6152e, tubular manifold, FIC 650's, wiseco/eagle internals, dsmlink, TRE tranny, Apexi dp and cat-back, Apexi EGT and Boost Gauges and Turbo Timer, Megan Racing FPR, Walboro 255 Pump and much more to come.
Old 03-05-2005, 01:01 AM
Re: Re: Re: Talon purchase concern.
LOL, you mistook what I said. It's called either a timing belt or timing chain, both referring to the same thing
Old 03-05-2005, 01:20 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
the eclipse's had a timing belt. if you plan to make this fast, i would just save for a turbo or awd turbo instead of spending the extra $$$ to make it turbo plus having all the supporting mods like tranny, gauges and that shit.
95 Talon TSI AWD
97 Eclipse GST
Old 03-05-2005, 01:21 AM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Save a bit more money and go for the turbo car.
Where abouts in Canada are you Raz? I am in AB.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-05-2005, 01:23 AM
I'm in Ontario-rio-rio-rio
And yea, don't be cheap like me and make irrational decisions when getting your first car...be patient
Old 03-05-2005, 10:58 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
raz kaz: a timing belt and a timing chain are two very different things. they both are used to drive the cam gears etc.. but a timing chain is like the chain on a bike its made of metal links. a timing belt is a belt with teeth. they both are used for the same purpose but they arent the same.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-07-2005, 12:41 PM
irupp33's Avatar
Ok But would a bad belt cause the same noise? It sounds like something hitting plastic. I want to get the car (talked the guy down to 2k for it) Because it is in remarkably great shape for a 92. I know it kinda sux for being a non turbo but i dont want a serious racer. (I have a 5.0 mustang also) I just want something that looks good is good on gas yet can still throw some aftermarket parts at and be able to smoke the occasional honda. My only concern is this noise. I want to make sure its nothing too huge.
1991 Eclipse GS-T
Exterior: stock
Old 03-07-2005, 12:57 PM
a timing belt wouldn't make the same noise as a chain would but you could have a bearing on a pull out or somethig of that nature that would cause that noise.
95 Talon TSI AWD
97 Eclipse GST
