Crankshaft seal replacement 97 Rodeo 3.2
I'm in the process of replacing: water pump, timing belt, tensioner, tensioner pulley, idler pully, and all regular belts. Since I've got it down this far should I replace this seal? It's not giving me a problem.........but believe it or not none of the above listed parts were giving me a problem "yet". The bearing in my fan bracket($135) seized and I thought it was the water pump. I know the timing belt had never been replaced so while I had it down, I thought I would freshen everything up behind the timing belt covers.
What is the usual life of this seal? Should I replace, or ride on? Since I've gone this far should I replace all radiator hoses, large and small? The rodeo has 90,000 miles on it. I bought it at 50,000. |
FWIW, I had timing belt, water pump, tensioner replaced at 60K. I'm now riding on 135,500 miles - have never replaced anything more then valve cover gaskets in regards to gaskets/seals.
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
I may just need to "ease up" on what I think I need to replace. If I keep it up I could work my way through the whole veh. I don't see any postings about the crankshaft seal, maybe it's not a problem.
Re: Re: Crankshaft seal replacement 97 Rodeo 3.2
I appreciate the post.
2003 Harley Davidson Firefighter Edition ![]() 1999 Ford F-150 Lariat ![]() 1997 Isuzu Rodeo 4WD ![]() 1955 Chevy 2DR Sedan Bel-Air "sweet"
Your welcome for the post.
I've never really heard of the front crankshaft seal leaking on a 3.2. You do hear of a leaking rear on the 3.2L on occasion . The rear main seal on my 2002 3.2L weeps a tad. Has done it since new. Just enough to see a small motor oil stain at the bottom of the bellhousing. Not enough to tear into it
!! G/luck JOel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
NO, NO, NO Don't say anything bad about the seals on the 3.2L, ESPECIALLY the rear main! Sssshh!
96 Rodeo 3.2L Mine is also leaking using Mobil 1 5-30 thinking about going to M1 10-30 or Dino to slow it down. Really cannot affort to fix it now. The M1 solved the top end ticking but found a way out of the rear main. Any suggestions ? Any success stories on slowing it down? I live in a cold climate area and need easy starting My rodeo is used mostly stop and go and short distances. |
Thicker oil??
Not quite sure, other then fixing it, on a 96 Rodeo it's probably just age that caught it .I shall talk VERY softly though , don't have any oil leaks - hopefully it stays that way.
