Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-04-2005, 09:37 PM
rettson rettson is offline
what transmissions can b used on "90 eclipse
i need a transmission but not sure what years are same as '90 eclipse or what other trans. could b used thanx
Old 03-06-2005, 12:43 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: what transmissions can b used on "90 eclipse
Not sure if the 1.8 trannys are different, both NTs are different, or all the same as turbo cars, but year make and model in your signature might help others that do know answer your question
If its a turbo car, you can use a 91-94 tranny, but you'll need the shifter cable bracket from the 90 IIRC. Wait a minute, is this auto or standard, WTF?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-15-2005, 11:39 AM
Erco90Talon Erco90Talon is offline
90 is a 90
for 1990 you can only use a 1990 unless you change some stuff like shifter, cables , arms on trans and maybe the starter if its manual
