Headlight removal info needed
Hello
I have a famous moisture leak into the right side hadlight assy. I want to remove it and re-seal the lens/reflector joint. Can anyone tell me how the assembly comes out? It is a narrow type 95' body style. Thanks |
Im guessing its similar to the contour. Theres 3 u shaped aluminum clips that hold the assembly on from the back. Slide those off and the headlight pulls out. Its easier to start from the passenger side to see what im talking about before you move onto the drivers side which is a little bit more difficult because of the battery.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
