Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 03-04-2005, 05:53 PM
=loki= =loki= is offline
VR6 idle issue + other question
Hi all.
I've search for an answer to this, but having trouble finding more specific info.
My 97 VR6 has an idling problem where the rpms will drop off to nothing, almost die then engine will rev back up past 1000. I've been told it could possibly be the idle control valve, but I'd like to have a better idea before I send it to a shop or pull it out myself.
Also wondering if anyones ever heard of a preformance coil pack for the VR6???
Thanks for any help you can provide.
Old 03-06-2005, 12:17 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
The idle control valve is part of the throttle body assmembly. You have to replace the whole thing. Also I dont think there is any "performance" coil packs out there. Just but a vw one, it will save you the hassle of problems. Also check for intake leaks, the intake boot from the MAF sensor to throttle body cracks alot and can cause a huge vacuum leak and revs to move like that.
Old 03-06-2005, 07:16 PM
good to know. BUt why is it then that you can buy the idle control valve separately???
interesting because i noticed a leak where the intake tube connects to the throttle body. Thought I fixed it but I wil check again. maybe make the fittment a bit better. Is it a horrible idea to use grease around the lip of the thorttle body where the intake and clamp go? I'm guessing silcone would be a horrible idea at that location.
thanks for your help.
Old 03-07-2005, 11:02 PM
VDUBMAN
yea.... uhh dont think your engine would like silicone to much.....
