Old 03-04-2005, 05:49 PM
Leoaviles Leoaviles is offline
car wont start
whats up guys well i just went to start my car and it did not start i pushed my alarm button and it worked but when i put my key in and try to turn it on my doors start unlocking and there is a clicking noise behind my glove box. the check engine light turned on and the battery light is on also. I didnt change anything or messed around with anything
it just went dead any ideas. could it be my alternator? I am running a 1600 watt amp?
i just removed the power cable for the amp from the battery and now the speedometer lights turn on and i hear a clicking in the fromt i think its the starter. the stero works fine though
Old 03-04-2005, 09:12 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: car wont start
turn the stereo off.
Have the battery and the alternator tested.
And don't run your stereo with the truck off.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-05-2005, 04:54 PM
Re: car wont start
i checked the battery and they said it was good i charged it and then put it back in and nothing changed could it be the alternator?
Old 03-05-2005, 05:13 PM
Sen Sen's Avatar
Sen Sen Sen Sen is offline
Re: car wont start
I had the same problem last week with mine.
it ended up being the starter.
The new Hitachi one goes for about $150cdn with a five year warranty.
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Faster and louder than stock, but nonetheless a blazer!
Old 03-05-2005, 07:23 PM
Re: car wont start
does anyone know where the starter is at
on a 98
Old 03-05-2005, 08:23 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: car wont start
on a 98
Same place it is on all the other trucks, passenger side at the base of the transmission against the flywheel.
Old 03-05-2005, 08:27 PM
Re: car wont start
ok thanks this is getting me fustrated i checkthe battery and its good i take the alternator off and go check it and its good. My next guess is the starter if not that than probably the fuel pump if its no that then....
Old 03-05-2005, 08:30 PM
rlith's Avatar
Re: car wont start
Look at your ignition module as well..
Old 03-05-2005, 08:34 PM
BlazerLT's Avatar
AF -Advisor
Take a voltmeter and go out to the battery and test the voltage and come back.
Use an actual voltmeter.
Old 03-06-2005, 07:20 PM
Re: car wont start
it read 7.8 and i tried to jumpstart it and it went up to 13.4 and still all i heard was clicking, could this be the starter?
Old 03-06-2005, 07:40 PM
BlazerLT's Avatar
AF -Advisor
Your battery is shot.
A fully charged battery will read 12.8-13.5 when up to proper level.
No way a battery can turn the engine over running only 7.8volts.
Old 03-06-2005, 08:06 PM
rlith's Avatar
If you want a solid shaft for 95 and up get the following
Borgeson 24" Telescoping shaft P/N: 450024
Borgeson 3/4"DD - 3/4"x30 spline U-joint P/N: 014931
Old 03-09-2005, 11:01 PM
Re: car wont start
i checked the battery and it was good then i take off the alternator and it was good. So i figured it had to be my starter so i take the starter off and go get it tested and they saidd it was bad it was not working so i get my battery checed and they charged it once more they said it was good. i bought a new starter for $150 and i connected the starter and then the battery and nothing happened. samething as before i would not start and all i heard was clicking. I have no idea what to check next any suggestions?
thanks guys
Old 03-10-2005, 01:26 AM
BlazerLT's Avatar
AF -Advisor
Re: car wont start
The battery is shot, take the voltmeter out to it and measure the voltage again.
Old 03-10-2005, 11:14 PM
Re: car wont start
good news guys i took my car to get checked out with a mechanic and i told him what was going on. He thought at first that it could of been the alarm i have on the blazer. He opened the hood and charged my battery with his charger and he tried turning it on and nothing happened he then opened the water compartment on the battery and he was like yeah its your battery.(i was like well autozone checked it twicw and said it was good) he said it smelled liked rotten eggs so i went to autozone and bought a new battery and installed it and it worked!! What a relief
starter- $150
Battery-$80
well thanks to everyone who helped and thanks LT you hit it right in the nose. any idea why my starter could of messed up?
