Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-04-2005, 04:44 PM
CaliLivin CaliLivin is offline
91 Caprice distributor Question
I have a 91 caprice that im converting to a carburated engine with a h.e.i distributor. Does the caprice's computer control anything on the old distributor? if so what does it do? and how can i wire my h.e.i to work in the car?
Old 03-04-2005, 08:00 PM
HLandin's Avatar
HLandin HLandin is offline
Why are you thinking of ripping out a perfectly good TBI and converting to a carb? Not only is the Model 220 better, it is also simpler than a 4 barrel carb. Check out the following web links:
http://www.goingfaster.com/spo/tbi.html
http://www.goingfaster.com/spo/praisetbi.html
Old 03-04-2005, 08:02 PM
dolluper dolluper is offline
Re: 91 Caprice distributor Question
We did it some years back and we discont the computer and ran a wire from the IGN switch for power to dist but there was something I'm trying to remember [the91 dist is shorter I think or we changed the gear and used an olds dist] otherwise cut a hole in your hood not positive i'll think and get back to you someone else might have a better memory
