Old 03-04-2005, 04:47 PM
slayme01 slayme01 is offline
97 blazer p code
My 97 blazer's engine light came on,so I took it to get it read.
A code came back that I had a transmission solenoid malfunction.
I think the code was p785(?).I have noticed since then,when I try to go from from a complete stop,it hesitates to go.But it does go.What is
the solenoid for?Could it be a simple fix?
Thanks
Old 03-04-2005, 04:53 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 blazer p code
we need the actual code.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-04-2005, 05:02 PM
blazee's Avatar
blazee blazee is offline
Problem?
Have you had any problems with it dying or the dash lights coming on and going off at strange times?
It's too early to say for sure, but the 97s have faulty ignition switches that will sometimes cause transmission solenoid codes.
Old 03-04-2005, 05:25 PM
Now that you mention it,my key is stuck in the ignition.It just started doing that today.
I have had no problems with it dying or the lights.
Old 03-04-2005, 07:01 PM
BlazerLT,
the code was P0785
Any help?
Old 03-04-2005, 10:17 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 97 blazer p code
Originally Posted by slayme01
BlazerLT,
the code was P0785
Any help?
P0785 - Shift Timing Solenoid
1997 + ignition issues + random transmission codes usually = ignition switch
Old 03-05-2005, 10:19 AM
So if i replace the ignition switch, the solenoid shouldn't act up?
Old 03-05-2005, 01:37 PM
BlazerLT's Avatar
AF -Advisor
In most cases yes, the ignition switch controls a lot.
Old 03-05-2005, 02:58 PM
Thanks BlazerLT.
I'll see what I can do.
Old 03-06-2005, 03:58 PM
BlazerLT,
One more thing.
When replacing the ignition switch,do I replace the cylinder in which the key goes into as well?If so,will it need to be coded?On a scale of 1-10,how difficult is this to do?I replaced a cylinder and switch on my 97 Camry and it wasn't that bad.
Thanks for any input.
Old 03-06-2005, 03:59 PM
BlazerLT's Avatar
AF -Advisor
no, just the electronic switch module
Old 04-08-2005, 11:49 AM
steener steener is offline
I have this same problem. Did you change the ignition switch? Did it cure the problem? How hard was it? Cost of the switch?
Old 04-08-2005, 11:51 AM
I forgot to say that I also had p 740, 753,758,1860,860.
Old 04-08-2005, 03:03 PM
BlazerLT's Avatar
AF -Advisor
Sounds like the ignition switch to me.
Old 04-08-2005, 10:12 PM
Thanks alot guys for the info. Replaced the ignition switch and everything is back to normal. Hour and fourty-five for me and I had my girlfriend there the whole time if you know what I mean.
