Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 03-04-2005, 02:28 PM
zoebowe zoebowe is offline
89 jeep
Hi,
I have a 89 YJ that stalls, backfires and dies when damp outside and I have the lights or turnsignal, windshield wipers on. Why would these electrical things have anything to do with the engine performance? I just had a tune up new wires,spark plugs,rotor pcv valve, they cleaned the thottle body and combustion chamber. Distributor cap, o2 sensor,cat convertor. The Jeep runs on when I shut it off they told me that they cannot adjust the timeing any more. Should I find someone else to work on my Jeep?
Thanks, jean
Old 05-17-2005, 12:32 AM
me_54451 me_54451 is offline
Cool Re: 89 jeep
I had similar problems with my 88 wrangler, and like you I started replacing electrical parts including the coil.The thing that did the trick was the electronic ignition control module. It is located under the antifreeze reservoir on the driver's side of my 88 wrangler.The part was about $65 but only took 15 minutes to put in.It was driving me nuts because it would run just fine one minute then not start the next,even after I had it in the shop.If you buy a chilton manual for your jeep and have a good electrical multitester you can run the primary & secondary electrical systems check.The chilton manual walks you through the process step by step, and wil by process of elimination tell you which component is most likely bad.I wish I would have done this before wasting money on parts I didn't need to replace,GOOD LUCK.
Old 05-17-2005, 02:33 AM
greyjeep greyjeep is offline
Does it stall, backfire , and die when you don't have them on? or is it just when those components are on?
Old 05-25-2005, 06:50 PM
Re: 89 jeep
Just when those are on.
Old 05-25-2005, 09:29 PM
bdiamond69 bdiamond69 is offline
i have a 89 it had the same problem the computer in side the dash is getting wet i bet yours run fine when it is dry out the this may not suond right but the simpleest way ti fix it is go get some silcone spay and cover the whole computer in it let it dry it you will never have that problem again
89 jeep wrangler with a 360 amc v8 40 over
msd ignition system from box to wires
edelbrock performer intake, cam
holly fuel inj
k&n air filter
tubro 400 trany with shift kit
dana 44 axles 4.56 gears
all 4 wheel power disc brakes
6 1/2 inchs of suspension lift
rci racing seats
simpson 5 point harness
griffin aluminum radiator
REAL JEEPS ARE BUILT NOT BOUGHT
LIFT IT --- FAT CHICKS CAN'T JUMP
