| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
knocking sound on a 95 gsx
My car sometimes, hardly ever has a knocking sound that you can here but it goes away right away. When it does happen its usually on 1,2,3 gear. When Im usually taking off not for a race just normal shifting without pressing the gas to much. There is sum guy that has a gst 96 and he says his car does the same thing not all the time but he says its normal. Anybody got and idea if its normal or what it is???
Re: knocking sound on a 95 gsx
Is it a knocking? Or does it sound more like ticking. If it does it at idle, which if it's a real problem it most likely will, can you give a rough idea of where the sound may be coming from?
Aaron B. 95 TSi DSMlink'ed Evo3'ed 6 bolt 52.7 1/4 second try 11.0 1/16th 2nd in league. 22.3 1/8th Ties league record. 6.6 55 meters |
Re: Re: knocking sound on a 95 gsx
That sounds like the standard lifter tick. I don't think I have heard an eclipse that hasn't had that problem. I wouldn't worry about it (and don't worry about it on my spyder)
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
my old motor had that problem , its a lifter tick , it shouldnt hurt much...
![]() 1998 Eagle Talon TSi AWD 6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband |
