Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-04-2005, 01:24 PM
nolikepoop nolikepoop is offline
Slipping problem after clutch replacement
Hi.
I had a new clutch put in my 95.5 Passport about 6 weeks ago. Since then, I have been back to the shop twice as the clutch pedal engagement slowly moves further out on the pedal. It only requires pushing it in about 1/2 inch before clutch engages. Eventually, the clutch begins slipping again just like before they replaced it. Each time I have taken it in, they bleed the clutch again and it is fine for a week or so, before the process starts over again. I just picked it up yesterday, and I can already feel the ratio moving back again.
Could this be a bad master/slave cylinder? Are they just bleeding it improperly?
This is my first hydraulic, so any comments would be appreciated.
Thanks.
Old 03-05-2005, 01:24 AM
Cat Fuzz Cat Fuzz is offline
Gotta be a bad hydraulic cylinder. I'd switch shops if no one there can figure that out.
Old 03-07-2005, 01:26 PM
Strange. For the last few days (it was bled again last week) I have been watching the hydraulic fluid level - no change. Now, after driving around town awhile, clutch slips again.
Could there be a seal bad somewhere? I thought I might be losing hydraulic fluid. I'd like to try to bleed it myself now and see if I can get the ratio lower on the pedal. Is there a valve on the cylinder?
Thanks
Old 03-07-2005, 11:12 PM
Bleeding the system over and over will not solve your problem. Something is obviously wrong. Either the clutch master cylinder or the slave cylinder are bad.
