Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-04-2005, 02:20 PM
samton samton is offline
Unhappy 95 blazer problems
have a95 blazer that dies everytime you stop, we have changed out the spark plugs and wires, coil and coil wire, new catalitic converter, there is no leakage around injectors, no codes come up...could the injectors be dirty
Old 03-04-2005, 02:55 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
Re: 95 blazer problems
try cleaning out the EGR valve.i too have a 95 and i had the same problem with mine. i cleaned it and it worked great.
Old 03-04-2005, 03:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Does it idle very rough when it does this and then cogh and die?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-04-2005, 03:24 PM
Re: Re: 95 blazer problems
it will rev up and then die
Old 03-04-2005, 03:29 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: 95 blazer problems
Will it start right back up and idle properly?
Old 03-04-2005, 03:32 PM
Re: Re: Re: Re: 95 blazer problems
yes it will restart and idle fine
Old 03-04-2005, 04:50 PM
BlazerLT's Avatar
AF -Advisor
ok, time to remove and clean you IAC valve and the hole it inserts into.
USE TB cleaner and a toothbrush.
Old 03-04-2005, 05:54 PM
im sorry when you restart it it will idle fine in nuetral but when put in drive have to gas it or it will die
Old 03-04-2005, 10:07 PM
will restart fine but have to keep foot on gas or will die again
Old 03-04-2005, 10:10 PM
BlazerLT's Avatar
AF -Advisor
Yes, clean the IAC.
And NEVER touch the gas on a fuel injected vehicle. You will just flood the engine.
Old 03-04-2005, 10:13 PM
Yes, clean the IAC.
ok thanks for the information...we will clean that part and you think this will help our problem
Old 03-08-2005, 04:49 PM
we cleaned the IAC and the EGR also and it didn't do any good, the truck still dies everytime you slow down to stop...
Old 03-08-2005, 04:54 PM
BlazerLT's Avatar
AF -Advisor
There was no carbon in the EGR valve?
Old 03-11-2005, 09:59 AM
No there was not and still dies every time you stop.
Old 03-11-2005, 03:07 PM
BlazerLT's Avatar
AF -Advisor
Go have your fuel pressure checked.
Closed Thread
