Go Back   Automotive Forums Car Chat > Cars in General
Old 03-04-2005, 02:06 PM
san diego san diego is offline
Unhappy rear wheel axel seal, right side
good friday to everyone. 2001 xlt expedition, i have had this truck for a few months with some minor problems. i took it in for a brake check and when they pulled the rear wheels off, we noticed oil from the the rear differential on the rotor guard of the brake, right side only. tehy want to replace this seal and turn the rotors and replace the pads. will this fix the squealing brake problem? thanks,
Old 03-15-2005, 05:05 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: rear wheel axel seal, right side
This is fuel economy related?
The seal should definately be replaced. If the pads got gear oil on them, they must be replaced. If you replace pads without turning/replacing rotors, they will most likely squeal more, and wear out faster.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
