Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-04-2005, 09:32 AM
ralgod79 ralgod79 is offline
start up
i have a 91 eclipse 1.8non turbo i get spark from the spark plugs,im getting gas to the engine ,everythings hooked up,but it rotates but doesnt fire up(start) any suggestions? Thanks
Old 03-04-2005, 08:55 PM
awd_n_it awd_n_it is offline
Send a message via MSN to awd_n_it
I don't know what to tell ya. The only thing i could think of off the top of my head would be that your gas is bad. Have you tryed shooting starting fluid in the throttle body or down the plug holes?
(Early) 1992.5 Eagle Talon
TSI AWD 5 Speed
Old 03-05-2005, 11:15 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: start up
do a compression test. autozone sells testers for 25 bucks
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-05-2005, 11:41 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: start up
What changed since it last ran. Any recent work, just isntalled this motor, etc. It could be 100 things, you'll have to help us narrow it down a bit
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-18-2005, 03:17 PM
Re: Re: start up
i changed the head gasket. what is envoled in changing over to a dohc non turbo?
Old 03-21-2005, 06:54 PM
SpyderGuy97's Avatar
SpyderGuy97 SpyderGuy97 is offline
Send a message via AIM to SpyderGuy97
Re: start up
I wouldnt suggest using starting fluid on a fuel injected vehicle, ive heard of it more than once actually blowing the head off the engine and streaching the bolts. I work at an auto parts store and one of the things we are told is that using starting fluid on a fuel injected car is a big no no.
Zack
Old 03-21-2005, 10:07 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: start up
did you get the plug wires put back on in the correct order? lol... it's been known to happen......
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
