Old 03-03-2005, 11:35 PM
LOUDCRXSi's Avatar
LOUDCRXSi LOUDCRXSi is offline
Send a message via AIM to LOUDCRXSi Send a message via Yahoo to LOUDCRXSi
Breather filter
Does anyone know if the breather filter does ne hard to the head. i've heard that the breather pulls in to much air and unevenly distributes the air into the valves and over time causes uneven wear on the valves. i dont understand the concept. i dont see the difference between the breather filter or the hose from the intake. either way i dont care if i get rid of it i just wana know b4 i take it off. i mean it kinda looks good on but it dont make a difference.
Old 03-03-2005, 11:40 PM
slow_99integra's Avatar
slow_99integra slow_99integra is offline
Re: Breather filter
never heard that. Who told you that?? or what web site did u see that on??
Old 03-04-2005, 12:32 AM
LOUDCRXSi's Avatar
Re: Breather filter
my friends dad...smitty i duno why you posted this when you called me.
Old 03-04-2005, 02:04 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Breather filter
it pushes air not, not sucking air in so instead of putting the air/oil vapor into yoru intake it just vents it. ive heard it can actually hurt your performance alittle, not much though
Team Lonely Drivers
Old 03-04-2005, 05:01 AM
Kven's Avatar
Kven Kven is offline
Re: Breather filter
some people have had problems where oil starts leaking out the breather filter and starts dripping behind the motor(this is because under the valve cover the cam and rocker arms are kicking the oil up and splashing it). i took mine off after reading its better to keep vacuum under the valve cover via by keeping the breather hose on the intake. i dont remember exactly but i think it has to do with the rocker arms having to push/pull air in when you use a breather filter, which causes energy to be wasted.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 03-04-2005, 11:48 AM
Re: Re: Breather filter
posted b4 i called u
Old 03-04-2005, 11:57 PM
LOUDCRXSi's Avatar
Re: Breather filter
my bad i thought it pulled air in
so i dont understand how the oil can leak from the breather filter but not the hose. i mean wouldnt the hose still have the same concept of the hose?? i've had mine on for bout 15,000 miles and i dont have that problem. im not disagreeing with you by ne means but if you could find the site you read that on that would be straight.
Old 03-06-2005, 02:29 AM
LOUDCRXSi's Avatar
Re: Breather filter
did i stump everybody?? i know im still confused....
Old 03-06-2005, 03:12 AM
Re: Breather filter
the hose is raised alittle to get to the intake so the oil has a hard time going up the hose. for example on my car, my intake or the intake side of my breather hose doesnt have any oil in it but when my friend took it off hte intake and shoved the hose facing down, i noticed oil leaking from the hose
but thats just alittle blow by, major blow by will put alittle oil into your intake. a good way to tell if you have blow by is to pull off hte hose and see if theres oil and also smell the air coming out and see if it smells like exhaust. also a compression check is a good indicator
Team Lonely Drivers
Old 03-06-2005, 09:19 PM
LOUDCRXSi's Avatar
Re: Breather filter
well i have the breather filter on now and i've never noticed ne problems with oil leaking. i was just wondering about that. and i've noticed that crate engines use breather filter instead of a hose. if breather filters are bad then why would they be on crate engines???
im assumin im ok with the breather filter. correct me if im wrong.
Old 03-07-2005, 12:20 PM
Re: Breather filter
you speak of these crate engines, ive never seen a crate engine before. show me
the reason most people put the filter on is because they dont want that oily vapor or oil going into there intake so they put the filter on
Team Lonely Drivers
Old 03-08-2005, 10:46 AM
LOUDCRXSi's Avatar
Re: Breather filter
you've never seen a crate engine for real??? im confused.
Old 03-08-2005, 12:07 PM
Re: Breather filter
show me a import crate engine
Team Lonely Drivers
Old 03-08-2005, 12:44 PM
http://www.high-performance-engines.com/b18c1.html
B18c1 crate engine
Old 03-08-2005, 12:48 PM
Re: Breather filter
breather filters on this crate engine's valve covers. check it out.
http://www.high-performance-engines.com/me09.html
