Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 03-03-2005, 10:23 PM
seņordos seņordos is offline
faulty brakes
I have a 1992 Mr2 n/a and sometimes when I press the brake pedal it sinks to the floor without actually braking until the very last minute. But if I press it down a couple times it works fine, so most of the time I have to press 2 times for the brakes to work properly. Anyone had a similar problem? what might be the cause?
Old 03-03-2005, 10:31 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
Re: faulty brakes
air bubbles, just bleed your brakes.
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 03-03-2005, 11:48 PM
Re: faulty brakes
bleed the lines or from the master cylinder it self? what about the lines that go to the wheels, would I have to bleed them too? thanks.
Old 03-04-2005, 07:12 AM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: faulty brakes
I would think it might be the master cylincer going out.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 03-04-2005, 12:45 PM
ac427cpe's Avatar
Re: faulty brakes
a master cylinder costs a bit more than a jug of brake fluid... i would bleed the brakes from the wheel lines, and if that doesn't fix it then look into a new master cylinder.
hello, i am Dan
Old 03-05-2005, 05:10 PM
Re: faulty brakes
thanks for the input guys. hopefully i just need to bleed the lines.
