hi, i just can give you some ideas how to repair for stop leak, i own a 1991 toyota tercel with the same problem, i change the both seals from the cover timing belt and the seal from the oil, that's stop all oil leaks on my car none drop of oil anymore, now if you will replace the seals from timming cover, you can change too the timming belt as well.. hope this can help..
Att
admin12
Originally Posted by artthefrt
It seems that the oil is coming down where the oil pan meets the transmission-is this the drive shaft seals >> the car has 170, 000 miles-a lotta oil comes out -mebbe a quart after driving 10 miles
