| Off-Topic Talk about anything other than cars. |
S-afc
Alright to start off im sure your all gonna say search it and youll find your answers. But i have and i still havent been able to find what im looking for, and i was hoping someone could give me a hand. I have a 92 TSI AWD, and i wanna put a S-AFC in it, the car has new injectors(bigger, but not sure on the size or type ) and a high flow fuel pump, and the previous owner had a S-AFC in the car. I dont have much background on the S-AFC, and i have searched for guides on how to use it and how to install it. If anyone knows a link that will help me out, or has some info for me that would be great. Again im sorry that im puttin this up because its most likely out there im just not typin in the right things when searching.
Thanks Tony
2000 Chevy Silverado 1500 4x4 Extended Cab. 1996 Pontiac Sunfire GT 5 Spd. 1992 Plymouth Laser RST AWD 5 Spd. |
Re: S-afc
http://www.vfaq.com/mods/gvr4_afc_instructions.html
There ya go. http://www.vfaq.com is a great site
1996 Eagle Talon |
Re: S-afc
Hey thanks for the sites, the first one helps alot!, But i have one q. So by installing the safc, do i still have to connect the plugs back into the ecu, or will the sfac do everything for me.......I get the feeling i have to just tie the safc into the back of each plug, and then plug them back into the ecu. Any help would be great! thank
Re: S-afc
P.S. I use vfaq alot and it works great too!
Re: S-afc
If you do choose to use the instructions from VFAQ make sure that you don't do the "blue wire mod" for the O2 sensor. It has been shown to degrade the O2 sensor voltage seen by the ECU. There is also a walkthrough posted here....
http://www.prostreetonline.com/pso/p...p?articleid=25 Enjoy!
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Re: S-afc
thanks, that about does it. i will be ordering my safc within the next couple weeks, lookin forward to gettin it all hooked up. Thanks
Tony
Re: S-afc
Go to www.racingknowledge.org, DSM section, and look at the AFC tuning guide Kyle put up. It should be considered the replacement for the RRE guide which is a bit dated, but the guide on RREs site does tell you how to set it up for a DSM (MAS type, cylinders, TPS type, etc). But use a logger and Kyle guide for actually tuning with it.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: S-afc
Thanks! Ill give it all a try!
Re: S-afc
in case you didnt find it here is the link....
http://www.racingknowledge.org/topic...tuning%2Cguide
![]() 1998 Eagle Talon TSi AWD 6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband |
Re: S-afc
Dsmlink has a full writen artical in their tech section about installing and tuning an afc. i thought it was a good read.
DSM geek |
