Old 03-03-2005, 09:23 PM
Btd36 Btd36 is offline
Question Speed sensor
Can anybody help me find the speed sensor. I pull out what I thought it was but it did not match the part they gave me?
Brian
Old 03-04-2005, 01:15 PM
crazymoon crazymoon is offline
if its the VSS(vehicle speed sensor) its in a very hard place to get at. took me 4 hours to get it done. The Sensor is located on top of the right front wheel drive shaft. It is a bit of a pain to get to. Locate where the 2 exhaust pipes meet at the rear of the engine. There is a Foil heat blanket covering the sensor area on top of the right side drive shaft. Remove the foil heat blanket and remove the sensor. good luck
Old 04-08-2005, 09:13 PM
STEVE MILLIS STEVE MILLIS is offline
Re: Speed sensor
Brian
CRAZYMOON IS CORRECT. JUST HAD IT REPLACED AND IT COST $262, PART $48,THE REST LABOR. THEY HAD TO DROP THE MOTOR MOUNT.
