Old 03-03-2005, 08:55 PM
jack'd up jack'd up is offline
'96 Voyager transmission slipping
I have a '96 Voyager 3.3L with a 4 speed auto trans. It started slipping the other day out of the blue on a long trip. Could this be electonic problem or just trans. going out. I have had the van for a year and everytime you put it into gear from park or N it makes a grinding noise ( sounds like plastic to plastic gears). Any help ?
Old 03-03-2005, 10:25 PM
Servant Servant is offline
Re: '96 Voyager transmission slipping
I have a 96 Dodge Grand Caravan. It is now on its 7th transmission replacement/repair (5 under warranty). Dodge denies any underlying problems with their transmissions. The data you can find with a little research proves otherwise. Things to watch for: slow shifting, forceful lurching on shifting, refusing to shift out of 2nd when your start up (stopping the engine and restarting at least gets you past this point). Good luck, I found that since I bought the van used (even thou I bought it from a dealer and with a warranty) the LEMON law did not apply nor would the dealer take the car back. The transmission fell apart the first time within 3 wks of purchase. As soon as I can get rid of this Dodge I will NEVER purchase another Chrysler product. We have always bought our vehicles slightly used and kept them about 10 years. This was our first and last Dodge.
Servant
Old 03-03-2005, 10:31 PM
Servant
Old 03-04-2005, 03:13 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
what's the level of the fluid? What color is it? How many miles are on it? Have you had it serviced recently?
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 03-04-2005, 10:40 AM
yoji6365 yoji6365 is offline
Make sure you have the correct AT fluid. Check the dipstick, it should say ATF +3. Do not use Dexron or additives. If in doubt, try a full flush and see how it does.
Old 03-31-2005, 12:31 PM
rebuilder rebuilder is offline
what your hearing is the solenoid pack cyling.that is normal,you did not say if anyone checked the fluid...../
