Old 03-03-2005, 08:31 PM
nortekd nortekd is offline
broken hood latch
I have a broken hood latch, something broke when trying to open the hood. How do I get the hood open, any help would be a blessing. Thanks
Old 03-04-2005, 01:54 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: broken hood latch
Did the cable snap or is it just jammed?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-04-2005, 05:11 PM
The cable itself broke approximately 2-3 ft inside the cable, I pulled that much out of the cable when it happened. I'm not sure what the next move should be.
Old 03-04-2005, 11:08 PM
TunerAdept TunerAdept is offline
jack it up, use a wrench or something to trigger the mechanism. replacing that part is just annoying. if you are sure its broke, as in "in the middle somewhere" you have no other alternative than to jack it up and use an L shaped something. i used a ratchet with a pivot head.
2005 2.2L Ecotec Cavalier LS Sport Manual 145hp/155tq
K&N Ram Air Intake "Typhoon Intake"
*comming*
upper/lower poly mounts
header 4-2-1 1.5 primaries
remote exhaust cutout/ hi flow cat/ hi flow muffler/ larger piping
Racing Spec grounding kit
-----then the fun mods start, but one step at a time-------
Old 03-04-2005, 11:49 PM
Thanks Tuner I appreciate your help, I'll give it a try and hope for the best. See ya
Old 03-05-2005, 09:06 AM
noshun's Avatar
noshun noshun is offline
What car, your profile says 91 cherokee!?!?! If it's a 2nd gen cav you can just remove the grille and get to the latch
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 03-09-2005, 12:13 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Even better experience for you. My cable broke on my 2nd gen, all you have to do is stick your arm through the"mouth" opening under the bumper, reach straight up and you'll feel the little lever where the wire connected. Just push that peice the the right (drivers side,) I've had to do this a hundred times, I've got a cable now but I still do it this way sometimes. It takes a few times to get used to where it is.
I saw another 2nd gen. for sale and wondered if it was TBI or MPI. It was locked, so, I poped the hood from the front, it's too easy.
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
