Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-03-2005, 08:31 PM
Stanger239 Stanger239 is offline
DRL and Headlights out HELP!!!!
I started my car today and the DRL indicator started flashing and then stoped. Then after that happned the service light came on, and I checked my headlights and they dont work...but my high beams do. and also while the indicator is flashing the DRL lights are flashing along with it. This is all with a 2000 sunfire GT.HELP HOW DO I FFIX THIS?
Old 03-07-2005, 10:37 AM
Brandish's Avatar
Brandish Brandish is offline
Re: DRL and Headlights out HELP!!!!
Could just be bulbs... Have someone look at the headlights while you start the car. Normally it'll flash your running lights on the one that's burnt out. As for the service light, I have no idea why that would come on unless the comp monitors headlights...
Old 03-12-2005, 09:03 AM
Juko Juko is offline
I have the same problem. I will tell you what it is not: the lightbulbs, or DRL relay (at least on my car). People have said in previous posts that the wiring harness may be bad because they wrapped it in duct tape. But I found none. Others have also said the gauge cluster may be bad.
Old 03-13-2005, 03:18 PM
trs's Avatar
trs trs is offline
i had tha same problem and all it was , was tha contacts in the light socket, i cleaned them and it worked fine after that and also if your light buld has burnted out itwill flash and the service light will come on too. check for both.
