Old 03-03-2005, 08:04 PM
crazykamper crazykamper is offline
Question HELP!!!! Studs broke off.
The studs broke off the front passenger side wheel. I was trying to take off the wheel to put on new tires, and the lugnuts came off with the studs, I went to the dealer, and they say to bring it in, I do not plan to tow it there. too much money. anybody know how to take off the broken studs??? any help would be great. Thanks
Old 03-03-2005, 09:51 PM
Scott82 Scott82 is offline
Re: HELP!!!! Studs broke off.
The way i usually do it, but it may be differ for your car is that i just knock the old ones out with a good size hammer and then start the new studs and put a lug nut on it and tightned it down with an impact untill it finally pulls into place
Old 03-03-2005, 10:37 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
what you do is take off the 2 main caliper bolts in the back which hold on the whole braking assembly, then the screws if there are any on the rotor. The whole thing should come off in one piece (caliper and rotor). Then take a big hammer and knock the old studs out. Put the new studs in and put the brakes back together. If you cant get ahold of a stud kit then use a lugnut and a washer to pull the stud through with an impact gun. Put washer on first and then the lugnut if you didnt know. Once its through all the way put the wheel back on. Acctually you can pull the stud through before you put the brakes back on.
1991 Honda Civic DX Sedan
Old 03-03-2005, 11:11 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
well i reccoment for you either going to by one of the repair manuals at a book store. it helps alot covers your whole car. and it will tell u how to replace one fo thsoe bolts if i do beleive.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 03-04-2005, 02:32 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Dude, do a search. someone posted a great illustrated step by step on how he fixed this problem himself on his civic,,, not too long ago.
Old 03-04-2005, 04:20 PM
CBURKE's Avatar
CBURKE CBURKE is offline
OK GUYS, UMM NO.....you can just knock them out. I wanted to put the skunk2 longer studs on and what do you know you have to press the hub out to get them out and put new one's in. unless you wanna cut the shit out of it and you can grind the back of the hub. I don't recomend this you may be weekining the hole thing
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
