Old 03-03-2005, 07:52 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
4G63 Internals
I have a really stupid question that I couldnt find searching. How much different are the internals from the 4G63 N/T then the 4G63 T and if there really different how much boost could the stock 4G63 handle.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 03-03-2005, 08:48 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: 4G63 Internals
the diffrence? the N/A 4g63's have no oil squirters, diffrent compression and diffrent cams.
DSM geek
Old 03-04-2005, 12:31 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 4G63 Internals
i'm guessing you're asking how much overall horsepower the stock 4g63 can handle, you just asked it in the question of boost. you can't really measure a set boost level on the 4g63, because it could be able to handle 35 psi of boost on a certain turbo, and only be able to handle 25 psi of boost on a different turbo.
a better way to ask the question would be how much horsepower can the stock 4g63 handle?
the stock 6-bolts have been known to handle 500+ hp.
now if you're asking about the boost level a 4g63 can handle with a specific turbo, then we need to know what turbo you have before we can answer that question.
95 Talon TSI AWD
97 Eclipse GST
Old 03-04-2005, 06:41 AM
macder macder is offline
Send a message via MSN to macder
Re: 4G63 Internals
You wont be able to run much boost on a 4g63NA since it has high compression pistons. The 4g63T has much lower compression then the NA. A 4g63NA is 9.2:1, where a 4g63 is 7.8:1 (on the 1g's, might be different on 2g's). Therefore if you put a stock 1g DSM turbo on the NA version at the same boost, you'd most likely blow you motor sooner then later (if not first time @ full boost). Unless you change your pistons and compression, you would have to set the boost really low. As for the 4g63T having different cams then the NA, i believe the exhaust cam is the different one. It's the same part # at the dealer for the intake cam.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 03-04-2005, 04:37 PM
Re: 4G63 Internals
I am replacing the pistons, cam, and all the needed parts to run a turbo with about 30-35 p.s.i. I dont have the turbo yet so I cant give you guys that info right now but I am changing what I said.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 03-04-2005, 07:01 PM
Re: 4G63 Internals
i believe the blocks are the same but the internals are different. if you replaced all the necessary parts with turbo ones, you shouldn't have any problem
95 Talon TSI AWD
97 Eclipse GST
Old 03-04-2005, 07:06 PM
Re: 4G63 Internals
yeah I think I am proly gonna do that to
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 03-05-2005, 10:57 AM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: 4G63 Internals
How much is that going to cost you? You might be better off finding a low mileage turbo motor. That way everything is there and ready to go, all you have to do is improve on it...just something to consider.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-05-2005, 02:41 PM
Re: 4G63 Internals
I was thinking of doing that but I am going to replace the internal anyway so ill just mod the NT out it woud save me money in the long run actually.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 03-05-2005, 06:53 PM
blue94eagletalon blue94eagletalon is offline
Re: 4G63 Internals
i want to turbo my 4g63 n/t. what do i have to change?
Old 03-05-2005, 09:43 PM
2of9 2of9 is offline
Re: 4G63 Internals
30 to 35 psi is alot for the n/t 4g63. Unless its a misstype.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 03-05-2005, 10:30 PM
Re: 4G63 Internals
shit i guess you didnt want to read my last post.
unless your running a APG60t, SMC61, T72, FP3052 there is no reasion to build a block to have to withstand 35psi!
i think you got it a little backwards. you build the block to withstand the compression needed to reach your goals with a specific turbo. take me for example. i know i want the SMC61 (650hp) from PTE. I want to run it with little lag and within effeceny island (20-25psi). with that i know i need to increase my stroke to help the displacment to spin the exhaust wheel faster to spool the turbo quicker. i know exactly what injectors i'll need at 12.5-13volts,pistons, head work exc.
Boost is nothing but hot air. your looking for Airflow!! anything ouside Effeceny on a turbo will give you hotter air. i guess im just saying find your goal with HP, and figgure out what you need to get there effecetly. More isn't always better.
Agian N/T 4g63 blocks do not have oil squirters to help lubricate the pistons. that does help oil pressure, but its a trade off. there are plenty of discusions on Dsmtuner about this. some people argue the fact the N/T block is a better block for higher HP#'s. There is no way around the pistons & rods. A big rod (stock 6bolt rods) setup with 2g pistons and some high temp rings with the right head setup will allow you to get 450 crank HP out of your block quite safely if built and tuned correctly.
DSM geek
Old 03-05-2005, 10:34 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 4G63 Internals
Unless I'm missunderstanding one or both of you, I think he means he is changing those internals to run 30-35 psi because he has the NT motor, which has pistons that are not only higher CR, but weaker. So he does have to build the motor in this case.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-07-2005, 05:25 PM
Re: 4G63 Internals
exactly thank you for saying that GSXracer
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
