Old 03-03-2005, 07:16 PM
donaldpla donaldpla is offline
Unhappy very frustrated, please give advise
Ok, I am having problems with my painting. I use Testors because its all they have within a 50 mile radius of me. Anyway, the gloss yellow which is acrylic is real thin. Even when I prime my parts, it takes so many coats for the color to take, and when it finally takes, there isn't much part detail left like there should be. I am also having trouble painting small areas, like around the stereo on a dashboard and small details. Any tips and help is greatly appreciated.
Old 03-03-2005, 07:31 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
the only advice i can give to your question is.... for small parts like radio and such. use a toothpick to paint knobs and stuff. instead of a paintbrush. it works trust me. hope this helps.
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 03-03-2005, 07:34 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: very frustrated, please give advise
I have found Testors light color paints to be very thin as well. I've also found that the pigments tend to settle to the bottom of the jar, and that's the main culpret. If you diligently stir the paint, getting all the pigment goo off the bottom (shaking won't get it all) it thickens up a bit. I also drop a BB in the jar, and that helps break up the pigment at the bottom when shaking. The paint is still on the thin side, but it usable.
Old 03-03-2005, 07:36 PM
primera man's Avatar
"P-Man"
How thick are you putting it on?
In cases like this you need to put very thin coats on allowing it to dry between coats before adding another.
To often people dont see the paint covering to well so they add more thinking it will help
View All My Models Here.
Old 03-03-2005, 08:35 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
huh? You dont have a wal mart within 50 miles?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 03-03-2005, 08:46 PM
freakmech's Avatar
[quote=donaldpla] I use Testors because its all they have within a 50 mile radius of me.
Also there are 2 hobbyshops within a 50 mile radius.
Creative Cajun-Lockport
Tri-City Hobby-Morgan City
I havent been so call to see what they have in stock for paint before making the trip.
Old 03-03-2005, 09:32 PM
scaleracecars scaleracecars is offline
Prime with white acrylic crush primer first. The yellow will come out right after only a couple of layers.
David
http://www.scaleracecars.com
Old 03-04-2005, 08:52 AM
Cobra Colors Cobra Colors is offline
Vendor
I've always found that the solvent based Testors enamels cover better than the acrylics. If you have the option to buy those that might help in the future.
Old 03-04-2005, 12:09 PM
hey freakmech
thanks, i never heard of them, but i will give them a shot. Do you know there locations?
And about Wal-Mart, I don't find they carry much.
Thanx y'all
Old 03-04-2005, 02:14 PM
HotRodDreamer HotRodDreamer is offline
Dude, you're so right about the thin yellow...I also use Testors and Model Master cuz it's all i can find, and the yellow's a real pain in the arse...I dont have any tips other than what was said, just wanted to add the description that it is pretty thin, but not as thin as light model master paints (which is a whole 'nother story) and it dries pretty quickly, at least from my experiences. The result's usually pretty nice though if you do 5 or 6 thin layers *remembers traction bars or whatever on the AMT Baldwin Motion 70 1/2 Camaro* Just my thoughts on the subject, and I too thank everyone cuz it's too cool of a color to just not use. Also an alternative to the toothpick that freakmech suggested, i use a sewing needle to apply paint and glue to small places, so it just depends on personal preference. Good luck with the paint though, donaldpla
