Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 03-03-2005, 06:51 PM
Dreamchaser Dreamchaser is offline
Question Turn Signal/Cornering Lamp
Does any body have a good way to change the turn signal/corning lamp on a 1997 deville. I have tried from the engine compartment and it is a tight squeez. Both lamps are on the passanger side of the car. If you could please give me any tips.
Thanks
Old 03-04-2005, 10:24 AM
caddydaddy caddydaddy is offline
Re: Turn Signal/Cornering Lamp
If it's like my '94 Deville, there is a little reverse torx bit that you need to get to remove a long screw. That then allows the side marker assembly to come out, and then it's real easy to change the bulbs! It took me only 5 minutes or less once you get the correct bit to remove the screw.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
