Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-03-2005, 06:34 PM
chubbysdad chubbysdad is offline
Send a message via AIM to chubbysdad Send a message via Yahoo to chubbysdad
98 ram died on wife :(
She was coming home from work and said the truck wouldn't go over 10 miles an hour. I got there to check it out and it ran fine. Well for about 5 minutes. THen when you gas it, it just doesn't go above 1000 rpm's. I was wondering if anyone had any idea's. Someone said the cat might be plugged? Would it do that after only 5 minutes of running? The truck never dies completely just wont rev up. And you can hear the sucking through the air cleaner get real loud. I took off the filter and housing and still makes that noise. My wife said when i hit the gas, it even smelt funny. Seems like the motor is running real hot too.
01 Jeep Wrangler 4.0 Lifted
2005 Dodge Ram with the Hemi
97 Jetta Gl
Old 03-03-2005, 06:58 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 98 ram died on wife :(
Chubby's mom? HAHA. He pm'ed me already.
Now that you mentioned the smell here, it might be the cat. I suggested the IAC and TPS earlier.
Bad gas?
How many miles on this truck? Er motor at least?
My Mopars
Old 03-03-2005, 07:01 PM
Re: Re: 98 ram died on wife :(
88,000 on truck. I just dont understand that if the truck sits then it runs great for 5 mins.
97 Jetta Gl
Old 03-03-2005, 07:46 PM
BleedDodge's Avatar
Running hot? What does the gauge say?
When my cat went the first time it made the passenger's side exhaust manifold red hot. Like glowing.
Is any exhaust coming out of the pipe?
My Mopars
Old 03-03-2005, 09:04 PM
Update,
My buddy moved my truck. Now the engine light came on and it even stalls now. Didn't run forthe first 5 minutes like last time. I had him check the exhaust and he said there is alot of air coming out. So I guess that rules out the cat. The other thing he said was when he was tryingto go down the road, while pressing on the gas the check engine light which is on now, it blinks when the gas pedal is applied.
97 Jetta Gl
Old 03-03-2005, 10:28 PM
hippikess hippikess is offline
Sometimes if the cat warms up the truck will run better, Or bad gas getting try getting a water remover\ fuel injector cleaner from a car parts store, it'll run you about two bucks
Old 03-04-2005, 09:31 AM
actually when the truck warmed up it got worse. Now it wont run at all and the check engine light did come on. I am having a mechanic just come and run the codes to see.
97 Jetta Gl
Old 03-05-2005, 05:57 AM
Re: Re: Re: 98 ram died on wife :(
Had guy come with computer. 1 and 7 not firing. So I Changed out plugs wires cap and rotor and still nothing. I will give an update when he comes back today with computer.
97 Jetta Gl
Old 03-05-2005, 10:43 AM
pintail pintail is offline
Is it getting fuel? My 98 ram 5.9 recently had similar symptoms, turned out to be the fuel pump - not cheap.
Old 03-05-2005, 03:46 PM
Yes checked the fuel pump and it is getting plenty of fuel. Found out that the cat is plugged. The only problem is the cat is welded to the head pipe and cant find that pipe at any local auto parts stores
97 Jetta Gl
Old 03-05-2005, 07:26 PM
BleedDodge's Avatar
Cut the converter out with a torch. Clean it out or replace it. Weld the new one back in the exhaust path.
My Mopars
Old 04-12-2005, 02:24 PM
Sapper69 Sapper69 is offline
it is the cat
